Hi all,
My loo has water running in to the bowl all of the time.
The cistern is concealed behind a tiled wall with access via the push button plate.
From memory, I think it is this Oli cistern.
https://www.oli-world.com/en/catego...nic-------------------/#Assembly Instructions
Every 30 seconds the cistern tops up for 2 or 3 seconds. Is it safe to assume that I just need to replace the outlet valve seal (part number 2 in the following PDF).
https://www.oli-world.com/download/190712050932657.pdf
