Toilets not flushing adequately (moved from f.information)
24 Nov 2015
Hi all.my toilets dont seem to be flushing correctly.
Theres plenty of water and pressure but its the direction the water comes out in ends up mising parts of the pan. Down the back and sides. Which means "debris" gets left behind
Ive got 3 toilets and they are the same so thibking it might be a design fault?
anybidy have any thoughts on stuff i could try?
Phil
Hard water area? Then try a metal coathanger to clear out the holes or Kilrock come in a little bottle with a brush.
Just seen "reported post" against this thread - What`s this all about and can I see the reason why?
because he put it in "forum information"
See here http://www.diynot.com/diy/
Are they all the same type of pan? Fixed flush, or the older type where you could have full or half flush to save water? Seems odd all 3 aren't working properly. :unsure:
