Just had some new insulation put down in the loft and I'm pleased with the new warmth I have gained in the house. The only problem is I planned to put down some loft boards, so I could throw a few boxes up there for storage, but the insulation is 30cm high and running in the opposite dirction to the joists. How can I board the area without removing the insulation? I rang the chaps who fitted it and they said it will squash down when I put a board on top. Won't this reduce the effectiveness of the insulation, as it must use the air trapped inside it? By flattening it to a pancake, won't that be defeating the object? Also, I was told there should always be a bit of a gap between insulation and loft board, to allow air to circulate and prvent moisture build up. Is this so?
As, I mentioned I'm very happy with the insulation side of things, and it will no doubt reduce my bills, but how to floor place now? I don't mind losing a bit of height in the loft ( it wasn't great to begin with, but I'm only putting boxes up there!)
I think 30cm is too high to run a new set of beams to which I coud fix a floor. They would have to be 32cm high and would not doubt bring the ceiling down!
any advice would be most welcome.
