The expert tilers will know of this, but I was left a very useful tool for drilling holes in tiles. Basically it is a small template with a variety of popular drill hole sizes with a small suction pad and lever attached.
The pad is moistened and the hole is positioned over the centre line of where you want the hole drilled. You then have a support and the exact location of where the drill should be to make the hole. Simply apply pressure as normal. The great advantage is the drill only moves through the tile and does not wander all over the tile surface. Helped me tonight as I drilled holes in porcelain floor tiles. Wall tiles tomorrow.
