    Dismiss Notice
Tool to trim bottom of skirting in situ
Discussion in 'Wood / Woodwork / Carpentry' started by seethrubabyblue, 30 Aug 2016.
  1. seethrubabyblue
    seethrubabyblue
    5 Dec 2012
    5
    Thanks Received:
    Country:
    Hi
    Can someone remind me of the name of the tool for this job? (I'm laying lino and want to tuck it under the skirting.)
    Many thanks
  2. timbo46
    timbo46
    27 Apr 2009
    64
    Thanks Received:
    9
    Country:
    France
    A door trimmer, or a biscuit joiner will do the job.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. JohnD
    JohnD
    15 Nov 2005
    68,817
    Thanks Received:
    3,825
    Crossgates
    Country:
    Cook Islands
    Or a multicutter, though I think you would want the semicircular blade or it may wander.
    • Thanks Thanks x 1
  5. JobAndKnock
    JobAndKnock
    30 Sep 2011
    5,031
    Thanks Received:
    1,089
    Lancashire
    Country:
    A jamb saw such as the Virutex RZ170. Multitools are all very well but they are incredibly slow and quite rough on long runs. Their blades also die if you happen to hit the masonry beneath or an embedded nail. Useful for finishing into corners where a biscuit jointer csn't reach (blade too small and nose design precludes cutting into a corner). Biscuit jointer work after a fashion but they have limited depth of cut and lack any form of blade height adjustment - but they can be bought cheaply enough, but if you need to work into a corner you'll need a multitools to finish the cut. The jamb saw has micrometer height adjustment, will work into corners but European ones (such as the Virutex) and American ones (Roberts, etc) are extremely expensive - typically £350 to £700 - but can be hired. They can be fitted with blades which will cut tile and brick.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    It would be easier to just remove the skirting. I used a spade to remove mine.
    • Thanks Thanks x 1
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
