Toolstation shallow inspection chambers
22 Jan 2010
Sussex
Have any of you guys ever installed one of these shallow inspection chambers?
http://www.toolstation.com/shop/Roo...+Chamber+Riser+110mm+600mm/d250/sd2868/p83067
James
Did youhave any problems with it? The tripple seal for 200mm riser doesnt seem to hold tight and seams to be two seaps from the nipple like things under the riser base! These seaps havesent me old a wild goose chase soimethingq that should have taken an hour to all put together has driven me up the wall most or the day!
Rant over
No did not seem to have a problem with ours. Bought it from a local supplier though. What make is it?
There is not a lot to go wrong, if the rim is not damaged, and the EPDM seal seated, and the plastic collar clipped on properly then it should seal.
honest of god woody this thing was like it was made by the devil. Slight level drop so re-did all connections then it just started dripping both sides from the nipple type things.
Lets see what tomorrow brings.
