long as you can vent at the highest point not a problem
as air won't go down hill
ok..just one final question...how would i connect one of these Air Vent Cap End Feeds to the tee in the loft....will i need add another tee into each of the existing tees and then add this air vent cap to the end thats left....if you know what i mean...i can understand if the pipe work in the loft was just supplying the towel rad, then it would be simple just to add a tee to each pipe and put on this end cap....i hope you can undersatnad what im trying to say..lol
no one type till i have a go!!
You can either fit a tee on each leg before the pipes hit the
tees or you can fit an extra tee as close to the existing tees as poss, point the tees upwards pop in a short piece of 15mm pipe then solder your vents to the top of these, thus making this part of your pipework at rad, the highest point! hope that made some sort of sense.
