Towel Rail Valve Fitting
29 Jun 2021
Ignorant question time:
Speedfit 10mm pipe will be coming out of a block wall that will be ultimately tiled and the wall-to-centre measurement for the towel rail is 57mm - 65mm. I’m thinking of using corner valves, with (2-piece) 15-to-10mm adaptors.
My uncertainty, and hence question, is the whether I am going to have any issues with connecting the pipe to the valves, with such a small piece of pipe sticking out of the wall? Any gotchas in there?
TIA
That should be enough to work with if you have allowed for the tile and adhesive thickness.
Blup
