TP9000 and TP4000 holiday mode
7 Mar 2005
I've recently moved into a new build with a Danfoss TP9000 programmer, a TS2 remote sensor in the living room and a TP4000 in the main bedroom. As I'm away for work quite regularly so I use the TP9000 holiday mode function. However, I just did an experiment and set the holiday mode to on but found that the TP4000 still functions.
Is that correct? It seems a bit daft to be able to set the hot water and downstairs heating to holiday mode but the upstairs heating will still come on/off while I'm away. Is there a way to modify the system so that holiday mode on the TP9000 switches off both zones? The alternative of course is to remember to manually put the TP4000 into frost protect when I go away and back to normal when I return.
Thanks in advance.
if you can afford it i would fit a hive or a nest, that way you can monitor everything while you are away, and when you are due home you can switch on the water and heating from your phone and everything is hot when you get in.
Thanks. I am already looking at the Nest system although I would need the 3rd generation plus another thermostat for the second zone (unless I convert the house to single zone).
I was hoping there would be an easier solution. I suspect the plumbers linked the TS2 thermostat to the airing cupboard zone valve and then directly on to boiler demand rather than via the TP9000.
Still looking at this. If anyone has any advice I'd appreciate it. In my previous post I meNt to say that the plumber had linked the upstairs TP4000 to the airing cupboard (TS2).
Is it possible to somehow use the TP9000 holiday mode to disable the upstairs TP4000?
