Trace a Radiator
6 Feb 2006
Oxford
I have tried to trace the manufacturer of a Radiator:-
RADEL heizelemente
It's a H700, 1000,30element
I am trying to find the heat specification
Tried the NET and failed!!
Maybe someone here can help
Regards
Berniejcole
go to stelrad.com find a rad that is as close to your dimmensions and that'll be as close as you should need.
Try a little harder. Though you have a word of German there, I found a Slovenian page which lists them.
http://www.fiver.si/?mid=3&style=red&pid=260&rid=196
and
http://www.fiver.si/CenikiFiver/Ogrevanje/Radiatorji/radel.pdf
Had a go at translating:
Radel konvertorski radiatorji so zelo učinkoviti, dobavljivi so v različnih višinah, dolžinah in tipih, tako da lahko zadovoljimo potrebam in željam še tako zahtevnega kupca.
which obviously comes out as:
Radel konvertorski radiator there are widely vigorously dobavljivi there are within Vesta virgin uphill , long plus tipih , so that with ease satisfier want plus yen ever so demander clientship.
So what IS your problem??? :lol:
By the way Radel aka DeLonghi
Much less fun but there are many hits on Google.de
ChrisR said:
Radel aka DeLonghi
Yes, when I recently took delivery of some "Delonghi" rads they turned out to be Radel. I asked my supplier (City Plumbing) what happened and they just said that Radel were the same as Delonghi. I still had a bad taste about it, a suspicion that I'd paid for a known brand and got a cheap substitute. Is that your issue?
Problem Solved.
My problem was similar to Chrishutt, expected Delonghi and received Radel.
Thanks for your help ChrisR
My standard searches did not show anything but I have looked at the site you mentioned and it gives me most of what I wanted.
Once again thanks to you both for your help.
Berniejcole
PS Antarctica & Cuba it's surprising where the help comes from.
