In trying to meet current regs in installing lighting in a new shower room, I've fitted a 6a RCBO to the non-RCD side of my cu linking the upstairs lighting circuit. All seemed well until I switched on a 2 way landing light that's on the same non-RCD buzz bar: at which point the RCBO clicked off - shutting down all of the upstairs lights.
However, once the RCB0 is switched off, there are no problems with the landing light wired to the 6a MCB on the non-RCD side.
In order to try and confine the areas to visit in correcting this problem, am I right in thinking that a fault in the 2 way wiring of the landing light could be causing the RCBO (connected through the same buzz bar) to click off.....or is there a more obvious answer?
