Hi all,
I was planning to hang one of these today:
https://www.travisperkins.co.uk/Moulded-6-Panel-Light-Glazed-Internal-Door/p/9000181824
However, I can't determine which side the lock block is on. The instructions state that it should be stamped on the top of the door, however there's nothing there beyond some info on the door size and a sticker - neither seem to indicate where the block is.
I've tried tapping down each side, but it sounds the same in each instance. I've also tried 2 x pilot holes per side, but again, there didn't seem to be any difference.
Is it possible that the door has a block on both sides?
Any advice would be much appreciated...
