    Dismiss Notice
Trees & Root Damage to Driveway
Discussion in 'In the Garden' started by greyam100, 16 Apr 2017.
  1. greyam100
    greyam100
    18 Oct 2014
    26
    Thanks Received:
    2
    Aberdeenshire
    Country:
    Hi Folks,
    My neighbour has some trees/bushes separating our driveways. One of the roots is cracking the surface of my drive, since before I bought the house. The damage doesn't seem to have worsened much, if any over last 4 years. Some photos here:
    https://www.diynot.com/diy/media/albums/driveway-front-garden.26088/
    We are looking to re-vamp our garden, complete with new driveway, but I'm not sure what should be done about the offending root(s). Our houses are built on engineered slopes made from compacted hardcore, typicall about 500mm below the surface, so I guess the roots don't have much depth to go to. A few queries:
    1. What types of trees are they?
    2. Best course of action to prevent the root damaging my new drive once laid?
    3. Will other roots below the surface start to cause problems, redirect themselves if they are exposed during removal and replacement of the driveway?
    Thanks in advance for any suggestions.
  2. endecotp
    endecotp
    2 Dec 2013
    3,431
    Thanks Received:
    429
    Country:
    They look like the dreaded Leylandii, and they look as if they have had their tops lopped and some lower branches removed at some point. (It's not impossible that it's some different but related species.)
    Have you spoken to the neighbour? It's not impossible that they would like to get rid of them apart from the issue of having less of a barrier for a few years while a replacement gets established.
    I'm not an expert, but I'd guess that the established roots won't move much now. But I'd go for a surface that will survive some movement, e.g. gravel or tarmac, rather than one that will show every mm of movement.
  3. Sponsored Links
  4. r896neo
    r896neo
    23 Feb 2007
    4,767
    Thanks Received:
    779
    Belfast
    Country:
    I have the exact same issue in my own drive, same trees same old tarmac drive lifted and cracked in places by roots. If you have the height clearance then Removing the tarmac, installing a geotextile membrane and hardcore then a new surface should mitigate any problems. This will leave you aprox 6'' higher than your current level. it would be essential to keep the trees well trimmed and not let them increase in height in particular.
    The only way to be sure is to remove them though and when i come to do my own I will remove them.
  5. lostinthelight
    lostinthelight
    11 Feb 2016
    2,116
    Thanks Received:
    389
    monmouthshire
    Country:
    Difficult to tell from the pics but Judging by the upright habit of some of the tips they may be Thuja, squash the foliage between the fingers, it it smells of oranges,it more than likely is.
    litl
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
