Trianco TRO 15/19 riello burner
5 Jan 2010
Norfolk
Our Trianco has started to make a buzzing sound when it has shut down for the day on time clock.
Turning the electric off waiting a minute turning on electric there is no sound the buzzing has stopped.
It starts heats radiators, starts and stops with thermostat setting, working every time on time clock.
Any ideas what the problem could be, Thanks for any help.
Is the buzzing sound coming from the boiler or from, as I suspect, an adjacent 3 port valve? If a Y plan has a heating demand when the timer switches off, the valve will stay in the heating position, with the synchron motor retaining power to the stall position. A new synchron motor will cure it. Switching off all power will let the valve close.
Three port Y valve is in the loft, I went to check noise and it was not coming from the vale.
But to be sure next time it happens will look again.
