Trim to worktop cut out
8 Feb 2025
What is best way to trim 3mm off one edge of existing work top ceramic hob cut out that is a tad too small to fit a new hob.
Work top is 38mm mdf maybe or something similar
is it an actual amount by trial fitting or expected amount??
does it need full length or just pinch points??
probably need at least 6mm to stop it skipping out unless you have circular saw and track or strait edge to run along to reduce skipping out
If it were me (with only very basic carpentry skills) I'd probably use a router.
off course the next question would be "what tools do you have" keeping in mind the likly answer will be a handsaw/jigsaw/other basic tools as anyone with a router would tend to know the answer without asking;)
as an aside worktop cutters are few and far between for 1/4 inch routers and would normally be dangerous or overloaded on a 1/4" shank but ideal up to 6mm shaves
point off note
with only 3mm to try and trim it will be almost impossible as the bottom off the blade will almost 100% defect off the surface and just skim across
my suggestion it aim the jigsaw at a minimum say 20 degrees in to the face and cut in till all teeth are a minimum 1.5mm into the surface then work round toward to a strait run at 6mm off line as this will give at least 4 or 5mm off timber [chipboard]on the open side off the blade otherwise as i said abouve it probably wont work
if you can only remove 3mm then you need to add timber to the open face to hold the face timber [or chipboard crumbs]you are cutting off to guide the blade
you will need a batton screwed on the open face at at least 3 points with an entry point for the jigsaw blade formed off a slot or drill hole that needs to be covered by the hob
then as you jigsaw remove screws and replace as you go to allow the blade to pass
