Hi, I have been doing some home DIY and somehow broken a circuit. There are only two scenarios where I potentially could have damaged to my knowledge.
- I initially drilled a shallow pilot hole when installing a curtain rail to check for electrics (my tester was only beeping for metal). On inspecting the pilot hole I couldn’t quite make it out but potentially saw something grey (potentially cable housing) and then a few specs of what I thought looked like copper. This didn’t trip the electrics and the sockets / lights in the immediate vicinity still worked. I installed the curtain pole elsewhere as didn’t want to risk that further.
- On installing a single socket my retaining screw hit the live wire, when switching back on the electrics it tripped the circuit. I stripped back the wire and re-installed. No further issues.
The issue I have is with a double power socket and an understairs light, neither work post something I’ve done. The are on either side of the same wall, but sit the opposite side of the room from from the first point. All other sockets and lights work in the property, my thoughts are whether the first did more damage than I expected, but would it trip when I turned the power back on?
Any thoughts or ways I could problem solve would be greatly appreciated. Note I have reset the circuit a number of times by means of switching all to off and then back to on, however to no prevail.
