how did you check it if you don't know where it is ?
this is the coil cost about £12
you can see it on my pic. it's not the same shower as yours but has the same layout.
just below the arrow where it has leak written.
it just pushes on a plastic spindle.
use a flat screwdriver to lever it then pull and it will come off.
