I've just moved house and the bathroom has a Triton Opal electric shower which was working fine for the last 2 weeks but yesterday I turned on the central heating for the first time and now the shower runs really hot even on the lowest setting.
Is it possible that the previous owner connected the hot water feed to the shower instead of the cold?
I'm going to drain all of the hot water out of the system and see if the shower temp returns to normal. If it doesn't then can someone suggest which part of the shower is broken?
There are 3 shower modes:
Double red squiggle - too hot to use on any temperature setting from 1 to 10.
Double blue squiggle - cold on any temperature setting.
Single red squiggle - lukewarm on any temperature setting.
I used to run it on double red squiggle on setting 3-4 which was comfortably warm.
It runs quite cold on double blue squiggle which kind of suggests that it is not fed from the hot water tank but the problem has only started since I turned on the central heating.
Possible it's just a coincidence that the shower has malfunctioned?
Thanks,
Isley
Thanks,
Isley
