Triton Ivory II reduced water flow problem - please help
5 Aug 2010
Oxfordshire
The water flow on my Triton Ivory II shower has suddenly reduced (everything else is fine) and I can't understand what's wrong. The other day we had a power cut while it was on and it seems to have got worse since then - can't be sure may be a coincidence.
Can anyone help ?
is the shower still running cold if temp dial set to 1 ?
the first thing you'll notice if the shower has reduced flow is it will only run hot on what is your normal showering temp
Thanks for the replies. The head isn't scaled up - I've tried removing it and flow is still weak.
The top control (cold, hot 1 hot 2) works fine - it will still provide cold water on the cold setting. The bottom temperature dial seems to have become a bit erratic in that you have to turn it up higher now to get the same temperature - sometimes !?
Probably easier to just buy a new shower !?
Any ideas/suggestions anyone ?
Cheers
Cheers
I have just replaced an ivory 2 for an ivory 4 ,straight swap,you can get an ivory 4 from homebase 9.5kw for £80 at the moment.
did you get anywhere with this problem? I have exactly the same fault with a Triton T100xr
thanks
