I've had a Triton T80 Easy-Fit for just over 2 years and it's started running hot then cold. It's been fine before and nothing has changed in terms of plumbing in the house. Set at full power, temperature knob in the middle it'll run for 2 minutes hot, then 1 minute cold, then hot again. The low pressure light is off and the flow doesn't appear to have changed.
I removed the hose and ran it straight from the unit, but it's the same issue. Anyone any idea what the issue might be and whether it's repairable? I'm fairly handy with plumbing and electrics unless you get down to soldering.
Thanks.
Thanks.
