Trouble finding concealed flush valve.
14 Mar 2006
Essex coast
Think it was produced in one of the east European countries, it’s similar to gerberit in that the valve is on the end of a flexi connector and clips into a bracket on the flush symphon.
But everything online is either bottom or side entry and this is neither.
You could try toiletspares.co.uk in Cheshire.
They have a good range of parts and delivered next day.
Do you need a top button?
Or what?
You say flush valve, so presumably you don't mean the supply pipe, just the flushing pipe which as you say usually comes out of the bottom, and the lever, handle, chain or button which as you say usually is on the front, side or top of the cistern.
I don't understand what you're looking for.
Can’t see how I can adapt , the current inlet valve does not fix to cistern casing , merely clip to a specific point on the flush valve .
This is the style of fitting, https://nationwidebathrooms.com/pro...MIm-61waHe4QIVmc13Ch2UGQbHEAQYFyABEgI6yfD_BwE
The inlet and float valve are on a flexi that clip into the flush valve.
The whole thing really so I can have spares , just discovered the brand is VidaXL .Only supplier I can find is on eBay , will see if they do spares .
