trv,s
3 Mar 2006
should these be fitted on the flow or the return on the radiator thanks.
kevplumb said:
most on sale now are bidirectional
my preference is the return
there is usually an arrow on the body indicating flow direction :wink:
the reason i ask kevplumb is that i have just moved into a flat with a bbu fitted and there is no diverter valve just a pump and a timer/ clock
i need to replace the clock and add trv,s to the rads would i also need to fit
a wall thermostat has well.
you should really to comply with part l
however having said that to comply properly you should convert the system to fully pumped etc etc etc
exept nobody does :lol: :wink:
kevplumb if i changed the system over to comply would i have to change the cylinder has well has there is 28mm pipe going to the coil in the cylinder.
which would you recommend to use the y plan or the s plan. thanks...karl
