- Joined
- 19 Jan 2005
- Messages
- 1,171
- Reaction score
- 41
- Country
Hi everyone
I've just had TRV's fitted to all rads and now need a bit of advice on how to adjust the room stat so that the TRV's work effectively.
The room stat is in the hallway which had 1 rad without a TRV. There are 2 bathrooms, neither with TRV's. All other rads have TRV's - one room has 2 rads (Kitchen)
A number of rooms in my house are used for work storage so they don't need to be kept that warm. Similarly the bedroom (that's what my husband is for! )
The heating is on timed - all day on, and off at night.
I have adjusted the TRV's to about the levels of heat I will want for each, but am unsure how to set the room stat. If this is not calling for heat, then I presume the TRVs won't open? Is this how they work? Does the room stat need to be set higher than I would have had it before?
Is it OK to have two differently set TRV's in the same room?
Hope you can help
Many thanks
SB
Edit - I suppose what I think I'm trying to ask is, does the room stat have to be set at the temp of the highest TRV?
Hope you can help
Many thanks
SB
