Hi
I'm about to remove a 'standard' rad and replace it with a towel heater. I've not done this before so the job may take me a little while, so can anyone advise me how best to close off the water supply to this rad while I fit the new radiator in place? I also need to do some tiling behind the radiator so it will be a day or 2 before the new rad is connected
I've got an 'open' system which is fed by a expansion cistern/tank in the loft. I also need to attach a bit more copper to each pipe entering the rad so it sits a bit higher off the floor.
If I just put a bung in the bottom of this tank, will this stop water coming through, giving me time to at least put closed valves or stop ends on until the other work is done?
Will having a single rad effectively closed off have any affect on the rest of the system (it's all a loop isn't it?).
Is there anything else I should be aware of? I don't want to have the system drained down if I can help it.
Thanks!
Thanks!
