TV mount brackets whats available?
14 Mar 2006
Essex coast
Have a 40" set I would like to mount on the edge of an alcove, ideally swinging thru like a door behind which I will install a shelf to take dvd, Wii etc so it's not all on show .
Need a 400mm mount but everything I have seen tends to swing on a short arm from the centre which won't have the required travel I need.
Anyone know of a solution? , may just have to make up my own bracket.
Thanks already done that, nothing suitable, all seem to be cantilever and I need one rigid arm which will adjust to a centre of around 20" to allow mounting to side wall and not the rear which is what they all appear to be designed for.
please bare in mind the wall construction if using a swing arm for a 40".
If you are using it to pull out all the time, Plaster board walls are naff!
Try AVF range. they are quite comprehensive and have a lifetime guarentee.
Hope it helps!
