- Joined
- 22 Aug 2006
- Messages
- 7,051
- Reaction score
- 1,174
- Country
The house has an old Profile 100 for the heating, and an old Ultra 50 for the hot water, both sealed, but separate. Both are about the right size for their respective loads, 22 radiators and a high recovery coil.
The thought is to replace both with two (Vaillant?) system boilers, keeping the two systems separate, but with valves and switches/relays fitted to allow cross-coupling, so one boiler can be used if the other fails.
To be able to isolate each boiler and couple the other seems to take half a dozen lever valves, with some complexity on the wiring, which is more awkward if each boiler has compensating controls. It is easier if they don't.
Is there anything available which caters for this sort of arrangement, off the shelf?
