Hello
I have a hallway with two lights. They are turned on and off by three seperate wall swithces.
They occasionally flickered. I discovered it was probably due to a faulty wall switch - but not after trying to completely rewire the ceiling roses.
I didn't make a note of how the roses were wired in the first place, and in hindsight I definately should have.
I think I have tried almost every combination of wiring, but I believe I have worked out that it is the earth wires that are causing the issues. I remember before changing the wiring, that the earth wires in the rose with the live swich wire, were wired in with the other wires, and not in the earth slot. That is why I decided to try and rewire them, because every diagram I found on the internet showed the earth wires going into the earth slot.
The picture below shows how the roses look, the first set-up is how certain diagrams I have found suggest they should be wired. Set-up two shows the nearest I have got to get at least one light working propertly.
Is this enough information to allow someone to very kindly give me some pointers?
http://www.magnoliaproperties.co.uk/rose.gif
Many thanks.
Ben
Many thanks.
Ben
