We only have Freeview and not planning an upgrade. The current set-up includes a joined coax cable. We have 2-3m from aerial to inside the roof space. This is then joined, a simple joint of both inner and outer, to the cable running down the wall into a socket below. Reception around Greater Manchester is fine.
We now want to add a second TV in an adjacent room. It's an easy task to fit a second socket and send the coax into the roof space. Is a simple 3-way joint of the coax acceptable or would you more knowledgeable guys recommend something different?
Many thanks in advance, much appreciated.
