I have fitted an Under Floor Heating System in our house, it has 6 zones, each with its own thermostat. Due to circumstances beyond my control, (shortage of cash), I ended up putting in 22mm chipboard flooring, on top of which is 10mm laminate. I would have preferred to use 18mm Engineered Wood but that wasn't possible. So consequently the heating is slower than it could have been.
I've just checked my flow meters and they're set at what I think is the maximum of 5L per minutes but that doesn't seem to be adequate.
My question for anyone who knows about these things is: Why do I need Flow Meters at all ??
I've read loads of stuff on 'balancing' a system, but do I need to care about that ?
It seems to me that max flow through my manifold would mean my zones would heat up more quickly allowing the thermostats to switch out the Activators as and when required.
So, can I remove the Meters ?? How could I blank the Meter holes in the manifold.
