UFOs
At the very least it must be classed as interesting and worthy of further investigation. None of us on here are qualified to deny that this is not a UFO.
If you watch it on your new massive tv in high def you will see that it is angular and has structure and appears to be partly in its own shadow making it look massive in the distance. So although a plume could be an explanation the separation plume is basically a big explosion of gasses and not angular
It definately has an angular shape which is an unatural shape in physics.
The problem is that he has pinned his life on lens flare and can not let it go regardless of how wrong he is.
If he had said separation plume then - yes that could be an explanation.
That would be the most stupid explanation possible. Even less likely than a blue glowing invisible UFO. You've got to be completely ignorant of orbital mechanics to think that would be loitering in frame.
So you dont think its the separation plume then. ( neither did I ) I just put it out there as a possibility.
Of course not, it's lens flare.
Then how do you explain it still being there in the same position to earth some minutes later only now smaller as starship has travelled away from it
What do you think it is.
An object in a geostationary orbit.
And on a list of other things it could be I would put the Epstein files in front of lens flare
The lens flare moved as the angle the light hits the lens changed. Of course it did, thats what lens flare does.
Then when the ship turned back to the same orientation the same lens flare returned, because of course it would. The angle was slightly different as the ship was further around it's orbit and not exactly the same orientation which is why it wasn't identical.
There is more than one type of lens flare, this is the same blue light lens flare we saw on the moon in the last idiocy thread. The usual gullible idiots were frothing about the blue lights in the sky and ignoring the blue lights on the ground.
Its pretty obvious if you think it through.
That's even more stupid than plumes. Geostationary orbit is 36,000km above the earth. You've gone back to thousands rather than hundreds of Km after all and we're back to (invisible) objects the size of a moon.
Its not the death star is it?
Geostationary orbit can be what ever distance you want it to be if you have a spaceship
That is not how it works.
I see that Justin has not come back with a reply to me question - flare or plume.
The more you reply with obvious disregard to the evidence in front of you that it can not be lens flare the more I wonder if you are paid by the intergalactic federation to deny and deny - surprised you haven’t suggested planet Venus or swamp gas.
You clearly wont admit that you are wrong so I give up on you and I will leave you to it and add you to the Ignore the trolls week thread
