It looks as if the ('average') regulation was extremely good. The daily average output voltages were perfect straight horizontal lines both before and after the 'step change' in supply voltage, the only difference being that the regulated voltage was about 1V less after the change in supply voltage. That seems odd, and it almost looks as if it was 're-configured' to a different desired output voltage at that time.Good question, no idea. However, the unit is (was) a double conversion unit so should hold the output voltage constant over a wide range of inputs - but there was always a small variation. I can only guess that with the reduction in input voltage, the DC bus voltage dropped, and the output followed suit as the voltage regulation in the converters isn't perfect.I also wonder why there was a reduction of about 1V in the UPS output when there was an ~8V 'step reduction' of supply voltage?
Kind Regards, John
