underfloor electric heating
13 Apr 2005
I want to use UFH in bathroom under ceramic tiles, I have a concrete subfloorwith 50mmx50mm battens at 400mm centres screwed to the concrete with 50mm Kingspan between the battens, then 18mm WBP plywood screwed every 150mm,
Question can I lay electric UFH matt direct onto this and tile over.
I have asked some manufactures and some say yes others say use cement based boards first,
I saw some under tile heating cable (not mat) and you had to coat the floor with some green sealant first. I can't for the life of me remember what it was called though. I'll have a look and if I can find it I'll post it.
Gcol
Oh right lol.
Well why can't you just decide on what heating system you're going to use and then ask that manufacturer what they recommend and run with it?
That way, if it goes t**s up you can always go back to them with a big stick.
Gcol
use "devimatt" elecctric underfloor heating-this is the best for the ease of installation/quality balance. 18mm wpb is part of the british standard for floor tiling on wooden surfaces in bathrooms, by the sound of it your floor is sound. use flexible tile adhesive. i've known for ufh to be installed on 6mm wpb and not cause problems. as for the green "stuff" described by another poster this is p.v.a. subfloor primer used with the "warm up" and "wickes" undertile heating. buy pva bond and dilute as sugested by the manufacturer. you should be ok. Check for "Part P" building regs 2005 requirements with regards to the electrics, bathrooms are a special location and as such need certificating, get it inspected and tested by a part p approved sparky, the cable sheathing will give you away if it all goes tits up later
Yeah Devi,the way to go,for ease and fitting.
i would personally lay a thermal board down over floor,,makes the heating soooo much more efficient.
Thanks for al the advice,I have more or less decided to go with "Devi" what sort of thickness and type of mat would you suggest?
I know this sounds duff but you really ought to have a look at the UFH that Fired Earth do for Bathrooms as it is in the matt form and is really user friendly. Also they do heating as well as warming mats and aren't to expensive
Sorry I meant to ask about thickness and type of thermal board [not mat]
