Im going to ask you all to think twice before going ahead and installing under floor heating. I have come across a big problem today which looks like it will leave me £8000 out of pocket! And i haven't even attempted to fit any flooring yet!
So my reasons for not having underfloor heating-
Electric type-
Can be dangerous as most are 240v, if any mistakes or damage happen with fitting. (Nothing like getting out of a bath and treading onto a wet floor that has mains voltage 3mm under your feet or maybe your young child that sticks a drawing pin or some thing similar through your lounge carpet into the 240v wires below)
It is also a health risk. Your kitchen floor sits there growing bacteria at a massive rate compared to normal situation.
Another health problem is that it can dry your skin and dust mites will love your warm carpet.
It can also cause structural problems. Over drying concrete and screed bases which makes them weak. Also cause levelling compounds to shear from the surface.
Your carpets will also dry out much faster causing delamination of the backing of the carpet. Can also cause your carpets to ruck after new install. Not a fitting error but the heat making the carpet grow.
Also can cause carpets to wear much faster.
Dont get thinking you can have that lovely wooden floor fitted you always wanted! Can destroy these to. I will leave this bit to some one else on the forum to make there own comments ( you know , just show its not me being the only person in the trade moaning here!
) woody help
You also cant just turn the heating off. You have to lower the temperature slowly other wise damage can been caused. Same for heating it back up to! Just what you want on a red hot day and your heating is stuck on. Or maybe your cold when you get home and turn the heat on
Guess what, You going to be sat there a few hours before you will feel the heat!
If there is any one else there out there in the trade that has more comments could you please post to help inform the public how rubbish and how much trouble under floor heating is. Thanks matt.
Electric type-
