Your underfloor heating should have its own 2.5 radial backed up by a 20 A rcbo. your fusebox is dated and your installation does not comply with the 17th edition regs. Get your Periodic inspection done and pay for the remedials!!!!!!!! standard
Your underfloor heating should have its own 2.5 radial why? if it's only rated to 3amp why not spur off ring final. if larger fair play put on it's own correctly rated circuit using contactor/snubber if required
backed up by a 20 A rcbo why not 16amp and why not use a stand alone rcd if rcbo cant be fitted or a 3036 is in use.
your fusebox is dated and your installation does not comply with the 17th edition regs if extending existing circuit just bring that circuit up to date along with meb@s & sup bonding
Get your Periodic inspection done and pay for the remedials!!!!!!!! standard I think you mean Electrical Installation Condition Report (EICR).
your fusebox is dated and your installation does not comply with the 17th edition regs if extending existing circuit just bring that circuit up to date along with meb's & sup bonding
