    Dismiss Notice
Underfloor heating mat and bathroom isolation
Discussion in 'Electrics UK' started by scorpiouk, 8 Jan 2017.
  1. scorpiouk
    scorpiouk
    30 Sep 2010
    70
    Thanks Received:
    Yorkshire
    Country:
    Hi guys,
    Having some work done in the bathroom. When finished the installer will have fitted a small heating mat under the new bathroom floor (<300W). I have a few questions about connecting it up.
    Previously the bathroom had a 6mm cable running from a wylex fuse box (with MCB type fuses), to a shower. This will no longer be required in the new setup..
    I was hoping I could repurpose the cable, change the MCB to a 6A type, connect it to a RCD and then feed the Heating and a small extractor fan from this..
    I was planning on using one of these: here
    Install on the outside, above the bathroom door.. Does this RCD give me the required level of isolation? Or do I need the isolation and the RCD.
    I have been unable to find an RCD that fits the old wylex fuse box, unless anyone know diffrent.
    Hope this makes sence..
    thanks
  2. Sponsored Links
  3. Taylortwocities
    Taylortwocities
    28 Jul 2006
    18,711
    Thanks Received:
    1,867
    Oxfordshire
    Country:
    I assume that your CU does not have RCD protection? If your Wylex board is of a more recent type then you could put in a 6A RCBO
    This would give you the RCD protection and current protection.
    The Powerbreaker RCD would do what you need with a 5amp fuse in it, without doing any changes to the consumer unit.
    BUT yoiu should be aware that the work you are contemplating (electrical work in the bathroom) is notifiable, so you'll need to be telling your local authority before you do anything and be prepared for them to want to inspect the work as it progresses. They'll probably expect you to be able to test and certify it all on completion.
    Or you could get a registered electrician to do it for you! A much cheaper option for a simple job like this.
  4. scorpiouk
    scorpiouk
    30 Sep 2010
    70
    Thanks Received:
    Yorkshire
    Country:
    Thanks for the reply...
    Your correct there is no RCD in the CU..
    Good point about the 5amp fuse..
    The change to the CU is just belt and braces, prevents someone adding more load later.
    I know it notifiable, but lots must be installed without being checked.:)
  5. deadshort
    deadshort
    20 Sep 2014
    2,086
    Thanks Received:
    211
    uk
    Country:
    What TTC said(y)
    Post a pic of the CU please, we can see if you can fit a RCBO.
    DS
  6. scorpiouk
    scorpiouk
    30 Sep 2010
    70
    Thanks Received:
    Yorkshire
    Country:
    this is the same unit, but not my picture here
  7. deadshort
    deadshort
    20 Sep 2014
    2,086
    Thanks Received:
    211
    uk
    Country:
    No sorry, these are too old for retrofit rcbo's.
    Your solution is fine remember the 5a fuse ! You don't have to derate the 32a mcb as the cable is 6mm.
    Regards,
    DS
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
