I am having my new bathroom installed and have had UFH fitted under my floor tiles. My bathroom fitters electrician came today to connect up my themostat and left without testing the system.
I turned on the system last night (tiles have been down 7 days) to test and as soon as the thermostat is switched to an 'on' setting, ie when it attempts to heat the mat the fuse is tripped on the main consumer unit. The RCD does not trip.
The electrician is returning today to investigate. Assuming he has wired it correctly, the system will stay on as long as it is not trying to heat the mat, i am fearing the worst and that the mat has been damaged during installation by my bathroom fitter or when he laid the tiles.
I assume this will result in lifting the floor and relaying the mat and tiles and as this is a wet room presumably some re-tanking would also be required.
I know i'm jumping the gun slightly as there might be a simple fix by the electrician but before i express my displeasure at my bathroom fitter would you reasonably expect him to bare the cost of this work to put it right?
Any advice would be appreciated
Simon.
Read more: http://www.tilersforums.co.uk/guest...amaged-during-installation.html#ixzz20xmrcKas
Simon.
