Hi
I am installing Underfloor Heating approx 18m2 @200w/m. I have a dedicated feed available(rcd protected) From The CU. Can someone please advise
1/ Do I need an FCU between the feed from the CU and the thermostat?
2/ If so what size fuse should I use?
3/ what size mcb at the CU?
4/ What size cable from the CU to the FCU?
5/ What size cable from the FCU to the thermostat. Flooring uses 1.5mm2?
PS I know I need to notify the local Authority.
Any advice much appreciated.
