Excuse my ignorance here
I have a 2 storey terraced house, circa 1910. I have a 2 feet tall crawlspace under almost all the house. The floors are all floorboards, some tongue and groove, some just planks with a few mm gap.
Is it possible to install a water-based underfloor heating system, I was thinking something like a single pipe per room (replacing the rad pipes), that followed the gap between each pair of joists, going up and down the length of the room? The pipe would turn 180 degrees at each wall to run down the next pair of joists (it would look a bit like an oven grille pattern). I was then thinking of packing the pipe up against the floorboards with insulating material, perhaps rockwool, or something more solid?
Its dead easy to get down there and run the pipe, theres loads of room.
Would this work? Or have I got the wrong end of the stick? Its just that my house has quite tall ceilings, and its impractical to close the doors downstairs to keep the heat in, also the staircase is open. Has anybody else tried this?
