There is a lot of talk these days when linking two buildings together underground using Cat5e/6 due to earthing differential between the two buildings from what I read and why Fiber is recommended.
Does this earthing differential is a factor if the two buildings had separate electric supplies with their own earth such as connecting between two neighbours houses?
So if you had a garage/workshop 30m or more down the yard and you wanted to run cat6, you would be fine especially if the garage's power electric supply comes from the same meter and same earthing system?
