Hi
Firstly, great site, dip in a lot but my first post.
I intend to tongue tite 18mm engineered wooden floor onto 6mm plywood screwed to existing 18mm floorboards. 6mm ply is used to even out the existing floorboards.
Question 1: do i need underlay i.e existing wooden floorboards -> 6mm plywood -> underlay -> engineered wooden flooring
Q2: there is a concrete hearth which will be covered. Can I just cover it with the ply or should I put underlay just over that?
I have seen this topic discovered at length but not exactly as above.
Thank you
LS
Thank you
LS
