Uneven filler
10 Jul 2016
I had some downlighters installed and there is an unsightly patch left where the original light was. It feels spongy so when trying to sand it makes no difference. This was done 1 week ago. Any ideas?
Thanks.
Hi it wasn't me it was the spark. He said he used decorators chaulk.
Brilliant choice---it does not set hard.
You need a bit of plaster board to fill the hole. If possible screw it to a joist where the original fitting was fixed. If no support available, yYou need a piece of plaster board as wide as the hole to fill, and a bit longer. Affix a string tail, apply plaster and insert it into and across the hole;use string to pull it down. You can then fill with filler or plaster.
Typical Spark, wish they would leave well alone and concentrate on their own job of making a mess for everyone else !!
