Hi all, I had these kitchen walls re-skimmed at the end of November and left it a couple of weeks to dry before applying a 50% mist coat of contract matt emulsion in December. All has been fine then a few weeks later I did a base coat of Little Greene Intelligent Matt Emulsion. Roll on about a month later and I noticed there's a spot in the door reveal where the paint and bubbled up. The walls are solid brick and the other side of this wall is a another thick garage wall. There's no real exposure to elements from the other side because of this.
The plaster had thoroughly dried before I did the mist coat, and it was 2 or 3 months before I proceeded with the rest, so plenty of time to breath, etc.
After seeing the damp spot I took my scraper and removed the blistered paint, sanded with some 120 grit mesh ready to paint again. The following day the spot is still a little damp and has lifted further:
Anyone know what's going on here and how I can paint it so that it doesn't lift again? I have some Zinsser Bulls Eye 1-2-3 Primer I can use, but suspect that's not the solution. I can't see where the moisure has come from though:
Inside of the garage, on the other side of the kitchen wall, which is also dry:
Can anyone suggest a way forward? Thanks!
