Hi all,
I am seeking an explanation for these symptoms with a Ravenheat LS80T Combi Boiler.
When I first turn the system on the central heating is turned off at the in-built timer and CH temp is turned down fully, the summer/winter push button switch is at the summer only setting. also no HW or cold water taps are open, however the fan and pump both operate immediately even though there is no call for hot water or CH. After 5-10 seconds the red overheat light comes on and stays on, the fan and pump continue to run, at no time does the boiler ignite or as far as I can tell even tries to.
If I turn on a HW tap nothing happens, no firing up, fan and pump continue to run, red light stays on.
If I turn on the CH via the summer /winter switch, temp control and timer, nothing happens, no firing up, fan and pump continue to run, red light stays on.
(All inlet valves under boiler are turned on and water pressure is at 1.5 bar)
The boiler is in my flat which I am in the process of selling, the buyer wants the system operational. I had an engineer in to look at it and he said the boiler was obsolete and he could not get the parts and he would not even look at it, he only wanted to sell me a new installation at £2,500. I have checked online for parts and they appear readily available, so I believe boiler is still serviceable.
I don't mind paying an Engineer to fix it, but having an idea of what is wrong before I ask would be useful.
I would very much appreciate any and all advice.
Thanks in advance.
Thanks in advance.
