Unidentified conduit
26 Aug 2007
Lancashire
Hello.
Pulling up floor boards in bathroom and I’ve come across what looks like a steel conduit. I say steel as one part is rusted. But what does it contain? Any ideas? I don’t want to cut into it in case it is of use, but I could do with removing it as it’s in the way. See photos.
Btw, semi detached house circa 1935.
Thanks in advance for informed help.
Why not undo the 3 screws and have a look. Most probably power cables. Can't be gas or water as that Tee isn't suitable.
How do I check if still in use??
It should have been replaced with modern wiring, decades ago - has the place been totally rewired?
Even then, the only way to be sure, is to trace where the conduit comes from, and goes to. It the ends are just cut off wires, then it should be fairly safe, to hacksaw through the conduit, and entirely remove it. If in doubt, get someone qualified in, to check it for you.
