I hang my head in shame asking, but realised I don't know the best practice of swapping o'rings and union joint washers! I've obviously changed things before and they've been fine, so just wondering if there is a correct way?
e.g. I've got to remove a vaillant diverter valve that breaks/disconnects 2x union joints to get to the DHW HE. A new diverter valve comes with new washers for diverter valve and o ring for the connection to the DHW HE. (And the DHW HE comes with new washers/o ring for its connections)
But just taking out and removing the diverter valve doesn't magic up new washers
- Assume that the o'rings and washers are single use and if should be replaced when the item is put back?
- Are the washers/o'rings put back "dry", or just "wet", or do they need any type of jointing compound?
- Do the UJs need PTFE or jointing compound when they are don back up compressing the washer?
