Unsure if my hob wiring needs upgrading
20 Feb 2015
Oxfordshire
I have an old Hotpoint solid plate hob that I am considering replacing. The wiring was done when the kitchen was installed.
The existing wiring is 3 core (red/live, black/neutral, and earth). I think it is 4mm copper. The wires are 5mm incl the covering.
Most new hobs I see require 30/32 A 'fuse rating. Looking on internet I am unsure whether my existing wiring is appropriate for that.
In your fuse box / consumer unit. What is the rating of the device which is marked hob or cooker ?
Are you talking about the approximate diameters of the red & black cores (including the insulation)?
Kind Regards, John
When I first checked my fuse box I was a bit confused but can now see the hob/cooker has a 30A fuse so I should be OK for quite a few new hobs.
Kind Regards, John
Yes I was. I turned the power off and measured the diameter of the wire.
Fair enough.
In that case, it's a pretty hefty cable, more than man enough for a 30A circuit.
Kind Regards, John
It'll be 6mm² and fine for whatever you buy.
Thanks for all the replies - I should have remembered my Pi R squared 8)
That's right. The bundle of copper strands in a 6mm² is around 3mm in overall diameter, from which πr² becomes 6mm². Add around 1mm of insulation 'all around' and that gives you the ~5mm overall diameter which you measured. As said, that's more than adequate for any cooker.
Kind Regards, John
