unsweating fitting without disturbing fitting 1inch below
18 Mar 2018
I need to unsweat a fitting without disturbing the fitting/elbow below it. I plan on wrapping the fitting in a wet rag/tissue but not sure if I still won't disturb it with it being so close. Anyone had this problem before?
Any one used the laco heat control gel? Usually just use thoroughly wet tissues.
As it's the top fitting, just wrapping the lower fitting in a well wetted rag should be OK. Grip the fitting to be removed with pliers, etc and use a bit of a turning force on it. As soon as the solder melts it will give and then twist off. If you are going to re-solder something onto the pipe where the fitting was removed from, re-apply the heat a couple more times to the pipe while also wiping off the melted solder with a dry rag. Wire wool or abrasive cloth should get any residue of solder off end of pipe.
