Hi - wonder if someone can give me an opinion. I am undecided whether I should pay thousands for a repair, or whether I'm just being scammed.
In short - I have a solar-powered hot water system (hot solar fluid gets piped through the inside of an unvented water cylinder). When the water from the taps isn't hot enough, my Ideal Logic boiler should kick in and top up the temperature.
That stopped happening - there was just luke-warm tap water coming out of the taps, and the boiler wasn't switching in to make it hot. (It shows "0" (standby) constantly on its display.)
Anyway, I called a plumber and he looked not at the boiler, but at the unvented cylinder in the cupboard. He noted brown, crusty build-up around where the pressure release valve (?) attaches near the top of the cylinder, which is crumbly and looks like the stuff which builds up on old batteries. He also showed me some water coming through the tundish - not masses but more than just a drip-drip. He called his boss on the phone who told him to tell me, the system wasn't safe, I shouldn't use it and we would need a new cylinder. He switched the whole system off and asked me to sign something on his phone screen to confirm he'd advised me not to use it.
10 minutes later the boss, who'd never set foot in the house, emailed me a quote for £2300.00 for a replacement cylinder and also phoned me and told me it could explode and take the roof off, and I should watch some videos of this happening to see how serious it was.
That's where I'm at - need to either get the work done, or know it's a scam and go elsewhere. Anyone got any suggestions? I can take photos of the system if it helps at all.
(Incidentally, the pressure release valve can be turned by hand, which opens the flow through the tundish, so it doesn't appear to be blocked.)
Thanks for any advice.
