- Joined
- 27 Mar 2021
- Messages
- 14
- Reaction score
- 0
- Country
Hi folks,
I am hoping there are some clever people on here who can guide me toward a solution with regard to a constant hot water discharge into a tundish.
Initially, about a 9 months ago, we had a problem with water pressure dropping in our central heating system. We have an unvented cylinder with a gas boiler. An initial call out from our maintenance contractor advised simply topping up the pressure. We did this on an increasingly regular basis to the point (daily) where we got another company into advise.
Since then we have had quite a few professionals in to change valves, replace expansion vessels, replace thermostats etc. Recently we have noticed the water discharge running constantly into the tundish. We have had intermittent leaks from the boiler also.
Another strange symptom is that the boiler fires even when it is set to OFF on the control panel. Our thoughts today were that the boiler is heating too much water causing the pressure to increase and causing the PRV to pass. From research this suggested a faulty auxiliary switch? However, having switched off the boiler at the mains, the water is still running to the tundish even without heat, suggesting it is a valve failure.
At this time, we think there are two issues - excess heat and valve failure. Does the valve activate the boiler? Any advice would be very welcome.
Thanks for your help.
Colin Gordon
Colin Gordon
