I am after some of your worldy advice. I had asked a similar question re combi or cylinder, and have decided on cylinder but I am now seeking a bit more knowledge on venter or unvented and any other types that exist.
Firstly, I am not installing anything, I will be getting professionals in. A lot of pipework will be being replaced, as it will be part of a considerable house renovation. It is possible that the supply may be changed, if the current supply is lead. The house is a mid-terrace property at the bottom of a hill, at the top of the hill sits a large resevoir that I presume must be the supply. I am yet to check the flow rate as I only complete on the purchase of the house next week.
I was wondering if a system boiler with an unvented cylinder is the best way to go, or are there other items on the market such as vented cylinders that would be a better idea.
My biggest concern is ensuring that I can have two bathrooms and a kitchen tap all running at the same time and that there will be sufficient hot water and pressure in that water.
It's a mid-terrace property. Boiler will be on the ground floor. There will be a downstairs loo, a 1st floor family bathroom, a 2nd floor ensuite bathroom.
I am aware that unvented cylinders are more complex to install and require certifications, that is not really of much concern as I intend to be getting the relevantly qualified people.
Thanks very much
Ross
Thanks very much
Ross
